84 150 black max .. engine cover HELP !
Maximerc
Any one with a simular engine ... When I bought this the engine face plate was laying in the transom well. The latches were gone on the engine. I went to merc and ordered the parts things were ok till I snapped the face plate on and then could not reach the spring loaded release. I am not sure if I am missing more of the latch or what ...I did finally get the face off by prying the top down .. If I install half of the engine cover and look at how things fit I find a small rectangle somewhat below the latch on the engine .. but impossible to reach a finger up there and trip the spring loaded latch.. What did Merc have in mind? I cant figgure this one out !!
Thecol
Re: 84 150 black max .. engine cover HELP !
IM NOT SURE BUT I HAVE 87 BLACKMAX 200 AND ITS PRETTY HARD ALSO
Maximerc
thecol.. what do you mean by hard? can you reach the relase?
KCLOST
You have the clam shell cowling correct?<br /><br />The face plate for that cowling should have a small lever just under the bottom of the face plate that releases it. And the top slides in and out of a grove where both clam shells close together.. If it's not like that, I can't help you....
Thecol
maximerc yes i have a small lever.spring loaded iam barely able to get a finger in there but i can.can you push yours up slightly from the bottom?because thats what i have to do.and it just barley makes it.i guess they are all like that
Thecol
the face plate sry about that
Maximerc
Yes it is the two clam shell design. I doubt I could even get a pencil up inther two hit that little "L"
dingbat
I'm not sure what is going on. My latch sits almost flush with the bottom of the face plate and its no problem to reach up and releasing the cover. I can e-mail a picture of mine if you would like.,
