changed stator to 14 amp and now im blowing fuses
bobrock
i recently changed my bad 7 amp stator with a new 14 am stator for a 200 merc 1988 and i blew out a 15 amp fuse at WoT... its ok at low rpm .... so i tried a 20 amp and poof .... so i tried a 30 amp now its fine ......also my batteries were in need of a charge so the draw was real heavy ...im wondering if i can hurt the engine some how? i have alot of devices to power including a 800 watt stereo amp ... wha cha think?? anyone?
achris
More fish than mountain goat
Re: changed stator to 14 amp and now im blowing fuses
Wha di tink?<br /><br />I tinks ya should put that th're battery on a charger and git 'im all charged up like. Then ya should git an ammeter and chick how mini of them th're amps is comin' out. 'Cause a 14 imp stator should no be put out more than 14 imps, ah?<br /><br />Cwis..........
bobrock
ummmmm yea ok whatever .... thx cwis ... i think
Trent
Your overloading your system. Divid volts into watts and that gives you the amps your drawing from the system.
bobrock
the fuse i blew was the one on the engine ... it works fine with a 25 amp too
