Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
I RECENTLY REPLACED MY ALUM PROP WITH A SS PROP ON MY 2003 MERC 2 STROKE 90 HP THATS WHEN I NOTICE THAT THIER WAS SOME END PLAY IN THE OUTPUT SHAFT (1/8 OF A INCH TRAVEL)IS THIS NORMAL?
If it was my motor i would take it back to the dealer and have them look at it.. such a new motor.. my 88 125 doesn't have any play in the output shaft
Boating4fun29,<br /><br />You'll probably find that your prop shaft does have about this much movement. It's just that the pin that moves the clutch is spring loaded. If you push on it you'll find the movement. 'bout 1/8" is normal.<br /><br />Chris.........
