GOOD NEWS. . . . The PICTURE UPLOAD FUNCTION IS WORKING !!! The tech folks at the parent company have been able to remedy the issue. You can upload pictures once again. Thank you for your patience.
Tom,<br /><br />I assume this engine has an external trim pump (mounted inside the boat) with 4 hoses that run to the trim cylinders. <br /><br />The trim motor itself is as Ben has said. You should only have a red and a black that run to the battery and a 5 wire harness that runs up to the controls (or a seperate trim control panel).<br /><br />Chris..........
