The trim pump on my 50HP Merc. is leaking. It is leaking from the part that is bolted to the pump, I am assuming this is a valve body of some sort. If looking at the unit from the front, the leak is on the right hand side of the valve body. It appears to be coming from a hole about 1/16 inch in diameter. Is this a vent hole of some sort? Is there supposed to be a welch plug or something in it? (there are no threads in the hole).<br /><br />When topped off with fluid it works just fine until all the fluid leaks out. Also what is the reverse lockout function on the unit do?<br /><br />Thanks <br />Paul
