1974 Mercury 115hp 6 cylinder running rough
Fishn-24/7
First boat and consequently first problems/questions. Mercury 1150 Thunderbolt 1974 serial number 3111159. I recently had a new shift cable and gear box and throttle cable installed. The reverese wasn't working properly. After they installed it the engine wouldn't hardly idle and would die when they engaged the drive. Being a beginner I took off each plug wire to check for spark and yes I am getting spark to all 6 cylinders. The distributor cap was dirty, so I cleaned. Notice it is a little worn but not to bad. Going from running decent to choppy as heck, what direction to I go from here? Adjustment somewhere? Clean carbs? Its just weird it happened right after they had it.
jimmbo
Re: 1974 Mercury 115hp 6 cylinder running rough
When "they" worked on it did it run fine for them? If so maybe they were using their own fuel tank with fresh gas. I would clean the carbs and gas tanks and try again with fresh gas/oil. Use a manufacturers oil be it Johnrude, yammaha, or Mercury.
emckelvy
They may have disturbed the throttle setting when they installed new control cables, or got the adjustment wrong. You do have to remove the throttle cable from the motor in order to get at the shift cable for replacement.<br /><br />Your motor should have a belt-driven distibutor on it. There are 3 screws on the front of the distributor, on a plate which is attached to the dist. with 2 bolts.<br /><br />One of the 3 screws says "idle stop" or words to that effect. This is the adjustment for idle speed. Don't touch the other 2 screws, one is the throttle stop and the other is for spark advance or "timing stop".<br /><br />If you loosen the locknut on the idle stop and turn the adjusting screw in (clockwise), it'll increase the idle speed.<br /><br />Note that after you adjust idle speed up or down, you may have to adjust the throttle cable for the correct amount of slack in the cable. When adjusted properly, the throttle cable should just barely push the distributor into the idle stop when the control lever is in neutral. You should be able to pull up on the fast idle lever then return to the stop when you put the lever down.<br /><br />You may also need to adjust the idle mixture on the carbs in the water, 1-1/2 to 1-3/4 turns out (ccw) from fully seated on the idle mix screws is a good place to start. Adjust for best idle quality, warmed up and in gear. If the motor bogs when taking off, richen (ccw) each screw 1/8 turn then try again.<br /><br />A compression check might be in order just to make sure everything's OK inside. And check the discussions about decarbonizing, Seafoam sometimes works wonders in that area. I'd run it thru the fuel system also, it could help.<br /><br />BTW, any self-respecting repair shop worth its salt would check the idle speed and shift action in a test tank after replacing control cables. I don't think I'd have them do any more work. Get a Seloc manual and you'll be able to do it yourself.<br /><br />HTH and Good Luck..............ed
Fishn-24/7
I appreciate the replys. I dug a little deaper to notice when I prime the bulb the middle carb leaks constantly. I'm sure thats not helping things much. Never done it before, but I am gonna try to clean carbs throughly and go from there. Thanks again.
jimmbo
The float is stuck on the leaky carb. try some gentle tapping on the flost bowl. It might free it.
Fishn-24/7
After decarbing with seafoam, engine runs better at high RPM but.....one carb still leaks when the bulb is primed. Carb kits? Needle stuck? Float stuck? I thought I had cleaned it pretty good but it still leaks out. The fuel filter won't maintain a constant pressure. Is there a link somewhere that shows how to properly disassemble the carb to clean float, needle, etc.?
emckelvy
Probably a good idea to replace at least the float and needle/seat on the one that's leaking. The newer-style needle/seat seals better, and the newer-style float does a better job than the old foam ones.<br /><br />Floats are available separately as are the needle/seat kits.<br /><br />The Maxrules site has a good section on doing carbs:<br /><br /> http://www.maxrules.com/carbindex.html <br /><br />This section should answer just about any question you might have about replacing the needles/seats and adjusting the float level:
ZmOz
Funny, last year I bought my first boat, with a '74 1500. Same exact problems....no reverse, and wouldn't go into gear. Seafoam made it run GREAT!
