1975 Mercury 402 - How to tilt?
ghaffy
Hello!<br /><br />I used the search-option but did not find an answer.<br /><br />I am afraid my question is a really stupid one, anyway I need your help:<br /><br />I just bought a boat with a 1975 Merc 402, drove a round on the water (worked fine), went home with the boat on the trailer and wanted at home to tilt up the engine.<br /><br />But I did not find a release button or so to release the "tilt bracket" (I dont know the proper word) - (At my Mariner 20HP there such a "tilt bracket releaser" just close to the Stop Button, you press it down, and then you may tilt the engine to the "prop out of the water - position".<br /><br />No such thing on the 402! Help me stupid guy, but how do I tilt this engine??<br /><br />(No power trim or electrical/hydraulic tilt aid, simply all mechanical)<br /><br />Thanks for your help<br />Andreas (from Austria/Europe)
Spidybot
Re: 1975 Mercury 402 - How to tilt?
Guten Tag, Andreas!<br /><br />Your motor will tilt when in Forward only. The reverse lock (prevents the motor from tilting when the prop pulls when reversing) keeps it locked down in Neutral and Reverse.
ghaffy
Hi UU!<br /><br />Thanks for your answer. Does this mean: simply push shift to FORWARD, and then tilt it?<br /><br />regards to Copenhagen from Vienna<br /><br />Andreas
Spidybot
Yes - it means that your motor is left in forward at all times when tilted.<br /><br />Needless to say this is done with the motor shut off. This also prevents starting as the motor cannot be started when in gear.<br /><br />An alternative would be to remove the tilt pin (if your gear lever for some reason gets stuck).<br /><br />When your motor is tilted you can see the locking system (hooks on to the tilt pin but can be seen only when the motor is tilted up).
ghaffy
Thanks,<br />exactly the answers I needed!<br /><br />regards<br />Andreas
