Merc 75 HP will only run at High Idle
Slickcraft
I put in an entry last night about a mercury 75 that won't start. <br />Serial #6503194<br />Model #1075524<br />year 84ish<br />well it started and will run but at high idle only. anytime I pull the throttle back it stalls. I have tried adjusting the idle mixture screww with only a little success. The manual says bring it back to 1&1/2 turns to start at idol but it won't start at Idol only with full throttle. I let it run for a while (20 min) hoping it would help it out in some way but when I pulled idle back it stalled again. Any Ideas. I have continued to adjust idol screws going CCW and that hasd helped but I still can't start engine in Idol or bring back to idol do I keep going richer.<br /> <br />ANy help is appreciated<br /><br />Slickcraft
Elmer Fudge
Re: Merc 75 HP will only run at High Idle
Could be it's time for the carbs to be rebuilt.
kev_79
Have you checked the timing?
Slickcraft
How do I check the timing and what is invovled in rebuilding carbs. I have taken them apart cleaned them and replaced needle and seat as well as the gaskets anything else.
Elmer Fudge
what's the condition of the plugs? do a compression test and post the results.
Slickcraft
Originally posted by Elmer Fudge:<br /> what's the condition of the plugs? do a compression test and post the results.
How do I do a compression test? and the plug seem to be in good shape fairly clean and good spark.
Elmer Fudge
remove the sparkplugs and ground the sparkplug wires to the motor, then screw on a compression guage in the top plug hole.<br />crank the motor for about 4 to 5 turn overs and write down the highest number reading.<br />Do this to all the other cylinders.<br />If a cylinder reads less than 15 psi of the highest number retained, try using some seafoam or quicksilver power tune to clean out any carbon buildup .
Slickcraft
IS quiksilver power tune or seafoam just a good idea anyway?... what is it and where does it go?also what is involved in cleaning carbs?... I have everything apart including fuel pump I was going to order a new diaphram should I consider ordering anything else...
Slickcraft
Ya know I would really love to get his boat in the water before the summer is up. Does anybody else expeirence the money pit of owning a boat or is it just me...
Elmer Fudge
Go to the FAQ section of this forum and click on decarb. If you have'nt a service manual for your motor, you can obtain one at the bottom left of the page. you'll need it to proceed
