1150 merc parts
jheron
I am going to replace the throttle cables on my MerControl and I am wondering if I should just order new ones from my closest merc dealer or if there are cheaper aftermarket cables I can purchase? I am also going to replace the hydraulic hoses on the power trim unit and the wiring harness that plugs into the motor, what are some of your valuable opinions on replacing these? <br />I am also going to add a tach. to the motor, will a standard tach be sufficiant? What is the red line on this old 115hp inline 6?<br />I live in Kitchener Ont. Canada.<br />Any and all advice is greatly appreciated!<br />Sincerely Jon
phatmanmike
Re: 1150 merc parts
aftermarket is less than half the cost. i purchased 16 foot cables at boaters world 2 weeks ago and they were 19.99 each.. dealer wanted 44.99 for each one.<br /><br />www.boatersworld.com<br /><br />what size do you need, i have a clean set of 12 feet i could let go , came included with a control box i order from ebay
jheron
Re: 1150 merc parts
Nice savings man! Thanks for the reply, I just happen to need 12' cables ;) Assuming the cables will work for my setup (mercontrol and 78 merc 1150) What do you want for them? Are they new?<br /><br />Do you know where I mite find a new hydraulic hose set for my mercury power trim after market? I dont see them at Boaters world, thanks for the link though :) <br />regards Jon
phatmanmike
Re: 1150 merc parts
they are used, i havent got them yet. they are due in tommorow from ups, they are actually being shippped from canadia.<br /><br />i have exact same motor, and yes they will work...<br /><br />if your not in a hurry, shoot me your email, and ill let you know when they come in<br /><br />m ikey
jheron
Re: 1150 merc parts
Thanks man check your email :) <br />So how do you like YOUR motor? Has it been fairly reliable? I have to rebuild my boat before I can put mine to the test :) I got it started fine before I pulled it off the boat so I heard it run for mabie 10 mins :) Sounds powerfull :) I have to get the prop and skeg welded up aswell as the previous owner must have had a thing for rocks... ouch.<br />Regards Jon
phatmanmike
Re: 1150 merc parts
read some of my earlier posts.... youll see how i like my motor, i LOVE it ! its a beast!<br /><br />no motor is bigger than a merc inline 6
jheron
Re: 1150 merc parts
Nice!! Glad to here the motor is a gem! Did you ever find a good place to get the wire harnes and plug that goes into the motor? Mine is rotted too. How about the hydraulic lines I cant seem to find anyone who sells just the lines, all the rubber is rotted off the outside of my hoses they look nice and white but I dont trust them!<br />Jon
Re: 1150 merc parts
jheron, The engine wiring harness may be obtained from any number of websites. I thought the price was lowest at www.surplusunlimited.com.<br /><br />The rubber on the exterior of my hydraulic hoses also fell off some years ago. I taped it with black electrical tape, and it looks OK. You could get some black wire covers from an auto parts store for a custom look. You can also wait for them to leak prior to replacing them!
sundog
Re: 1150 merc parts
I have the same engine, guys, and thats about the only thing on my boat that I -can- count on. I looked into getting my Trim hydrolic lines replaced, and they wanted some un-godly amount for them (Ive mentally blocked out the price). I dont see why a set of truck hydro lines wouldnt work. gonna wait for mine to blow up, then Ill try it. My choke solenoid is beginning to fail, but other than that, its a gem.
