pre load pin removel
rusty bolts
Hello,to all . The problem is that the preload broke on removel of lower. How can i get the old one out and how do i get a new one it .thanks in advance JD The lower unit is off a 1979 175 black max.
achris
More fish than mountain goat
Re: pre load pin removel
Hi rusty,<br /><br />Welcome to a fun group. <br /><br />If the pin is stuck in the bottom of the crank, then you'll have to remove the powerhead and work in the bottom end of the crank. As for a new pin, just buy a new one, and spring, and put them in the end of the driveshaft and while they're compressed, stake it.<br /><br /><br />Chris.............
rusty bolts
Thanks Chris,the problem is i do not know how to get what is left of the old one out of the drive shaft.When you meen stake it ,is that why there is a + on top and that holds the pin in. i cant seem to get it out .will drilling it work? thanks Rusty
achris
Is the pin broken? If there's any of it exposed, grab it with a set of tower pincers. Yes, that '+' it where the original was staked.<br /><br />Chris.........
rusty bolts
yes it is broken off inside ,can i drill it out?Or is there a trick to it . thanks rusty
rusty bolts
achris
Don't thin kdrilling will work. It's a spring loaded pin and once the drill 'bites' the pin will just spin. Try opening the exsisting stakes. It should just pop out under spring tension.<br /><br />Chris.............
rusty bolts
THANKS CHRIS for the help .the way i got it out is,drilled a small hole it the top and used a all to pry it out.I guess i got lucky.
