Jud Hamblett
Thread starter- Joined
- Nov 16, 2002
- 23
Motor is a 2002, Mercury 115, EFI four stroke. 225 hours. Water pump replaced at 100 hours. Water pressure gauge shows zero pressure or barely moves. Removed Gauge water tube from block. No water coming out gauge fitting at the block at idle or even 3,000 rpm.<br /><br />However, telltale give steady stream and good water flow from large water tube leading from T Stat to side of block. Head feels cool all over, and no alarms sound. Reconnected gauge tube at block and disconnected tube at the gauge and ran motor. After 30 minutes or so of running steady warm water stream comes out at guage tube end. Reconnected tube to guage - all is fine water pressure at 5,000 up to 23 pounds, idle around 5-10. <br /><br />Two weeks later same routine no pressure indication at gauge (no water column reaching gauge) , no water pressure coming out of the block at gauge tube attachment point. Then after running a good hour, warm water squirts out of gauge tube. Reconnected gauge tube, and all is fine. <br /><br />No idea why what is causing the problem
help please.
