NEED HELP GETTING SHOCKED
MATTKENSETH
WHEN I HAVE THE COVER OFF THE MOTOR AND STUFF I NOTICED THAT IF YOU TOUCHED THE PASSANGER SIDE PLUG WIRES WITH ANYTHING IT GAVE OUT A SHOCK.<br />DOES ANYONE KNOW WHAT CAN CAUSE THIS????????????
ronmold
Re: NEED HELP GETTING SHOCKED
High voltage generally causes shocks.<br />plug wires could be bad/cracked. This could lead to poor performance.
DHPMARINE
I think this is caused by the 30,000 to 40,000 volts the coils/CDI's put out.<br />DHP
MATTKENSETH
BRAND NEW PLUG WIRES AND PLUGS ALSO TRYED A DIFFERENT SET AND SAME THING ALSO CHANGED IGNITION CABLES AND VOLTAGE REGULATORS ALSO STATOR WAS CHANGED
DHPMARINE
I thought it was an indication not to touch them!<br />How does it run?Spark goes to ground the quickest way it can.<br />DHP
jfholijr
hmm?? sounds like your gettin shocked pretty well all by yourself there
snappernz
some people arent silly enough to grab the wires twice
