watercruiser
Thread starter- Joined
- Aug 31, 2004
- 11
OK, I was a mechanic many years ago so I have some inclination but I lost most interest.<br /><br />I have detailed my problem fully so as not to get chance guessing here ...<br /><br />FACTS:<br />Just had some work done on it (long shaft extension and remote throttle) and my guy is now out of town for a week<br /><br />It's a mercury 1995 8hp 2 stroke but very low hours, clean new plugs.<br />New fuel tank<br />New fuel 50:1<br />New hose (very very very light leak next to bulb nothing major) about 3ft hose run to motor from tank<br />Engine starts from cold start everytime and ticks over (idles) nicely<br />Fuel Tank vent open !<br />Cooling working fine<br /><br />PROBLEM:<br />Took the boat out last night to try my new fangled remote control throttle and long shaft<br />Ran like a dream into the bay<br />Decided to do some integrity testing so I did some slow/fast runs, reverse runs into waves etc..in 2+ ft swell.<br />1st problem, I idled for a moment then went into reverse (it's a gear shift then throttle all in one manouvre)<br />Engine stalled, OK maybe too much current working on propellor ?<br />Tried again and managed to play around in reverse just to see it's performance. Not great but not bad. No issue.<br />Ran around a little more things seemed fine all in all.<br />2nd problem happened coming back to my slip<br />Slowed down to idle/neutral on approach. Engine seemed OK<br />The engine up to this point had been running for about 45 minutes no problem<br />Hit the gas in forward a little to keep momentum, and it stalled<br />Ran past T head and swung out for room<br />Tried starting, no joy, pumped the bulb a few times just in case of fuel starvation<br />ONLY way to start it was to pull out the CHOKE FULL and it started first pull<br />Turned off choke and it idled fine, put it into forward, same again STALL !<br />Had to do this about 10 times, managed to gun it into slip with wind and momentum<br />Havin tied up I tried motor again, SAME issue, wouldn't start but would start on CHOKE it starts without a problem<br />Leave it idle for about 1 min, it then COUGHS a little, then slowly dies down to stall<br />Start in with CHOKE again, try putting it in forward, and .. YES you guessed it STALL.<br /><br />SYNOPSIS:<br />So I have a warm engine that wont start unless you CHOKE on.<br />To me that's maybe an AIR problem ??<br /><br />So if any of you are guru's here do you have any good idea what it might be ?<br /><br />Sorry for the long tale I just want to avoid the usual suggestions like fuel/hoses/idle speed etc.<br /><br />Thanks for any helpers<br />Alan
