Motor Died!!!
bozzanddww3
Re: Motor Died!!!
Thnx OB, All I know is that the cable that comes from the control on the side of the driver's console goes all the way back to the motor. I am thinking the lighter has it's power coming from another battery. This is really getting depressing!!!
bozzanddww3
Re: Motor Died!!!
Originally posted by hotrod007:<br /> Well then start at square one. search "no spark" there are a lot of great trouble shooting tips here for "no spark".<br /><br />When I had "no spark" I believe the first and best one to do is unplug the main harness and try starting her by jumping the starter to solenoid.<br /><br />Unplugging the harness bypasses the kill switch and the ignition, that will rule them out.<br /><br />You should confirm “no spark first” You may have spark
I stuck my screwdriver in the plug wire yesterday and let them turn it over while I helt it to the motor. Nothing. You never even hear the motor trying to fire
bozzanddww3
Re: Motor Died!!!
Maybe that reply didn't go thru as it should have but what i was saying is that when it happened, I pulled 2 different plug wires and stuck a screwdriver in there and stuck it to the engine. Nothing.
Hotrods
Re: Motor Died!!!
I'll bet yu your wife it's your kill switch :D .<br /><br />Yu,know yu Should always keep the same topic going ;)
bozzanddww3
Re: Motor Died!!!
OK, YOU CAN HAVE MY (EX) WIFE IF HER HUSBAND AGREES! ALSO, IT WASN'T REALLLY "THE" KILL SWITCH, ONLY THE ONE TO KEEP ANYBODY FROM CRANKING IT IN THE HAULING POSITION. nOT LIKE A NORMAL KILL SWITCH. sORRY ABOUT NOT KEEPING EVERYTHING IN THE SAME THREAD!! hECK, YOU KNOW i DON'T GOT NO SENSE IF I GOT MYSELF INTO THIS JAM WITHOUT AT LEAST TAKING THE TROLLING MOTOR!!! THANKS FOR EVERYTHING AND GOOD LUCK WITH THE WIFE!!! (GRINS) AM ON MY WAY TO THE RIVER IN ABOUT 30 MINUTES TO TASTE THE DRUITS OF MY LABORS. HAVE A GOOD ONE!!!!!!!!!
Chucky P
Re: Motor Died!!!
Take the orange wires off the switch box There should be two .on the motor .one will go to the harness going to control box,then another will go to small round tube. try to start
