Re: What went wrong with 150 XR2
copy from another post<br /><br />semi,<br /><br />The first and easiest thing to check is the spark on all the cylinders.... <br /><br />Run the engine on the muffs at idle... Use a spark gap tester which you can buy at any auto parts store for around $10....Set the tester on one lead to the plug at a time before starting the motor. And set the gap at 1/4"-3/8" for starters... The gap tester allows you to test each lead and still have it grounded to the plug.. If the spark is strong enough it will jump the gap and you can see it easily without shocking the hell out of yourself by doing this the old fasioned way...<br /><br />Switchboxes have been known to go in and out of operation with changes in temperature... So this may be the cause of your problem... So checking the spark at cold/idle conditions is my best recommendation...And I should add, that a weak spark can also cause your problem at lower rpms...<br />A weak spark can be related to something besides the switchbox, but we will get to that later. Let us know what spark intensities you have on each.<br /><br />If you have only one cylinder not firing, it's very possible the boat will not get on plane... I have a Ranger 371V that "barely" got on plane with only one cylinder not firing... <br />If we check the spark first we will know if it's electrical or not, if the firing is ok, we will then need to check compression and fuel...<br /><br />Fuel/air+compression+spark=combustion
