Help, mercury motor
johnlj68
I have a mercury motor that is an in-line 6. I need help finding year. Here is the serial # on the tag 3942837. It has on the cover a thunderbolt ignition. also would like to whats the gas to oil ratio on this thing, as i cant find anywhere to put in oil. I dont know anything about this motor, so any help would be appreciated. thanks, john
johnlj68
Re: Help, mercury motor
Also, can i run this motor out of water? if so, how long before it does any damage? thanks, John
Clams Canino
The gas / oil mix is 50/1 That's 1/2 a quart for a six gallon tank. You add the oil in the tank then pump the gas.<br /><br />It's out of the 70's - I don't look up years, because they're all the same.<br /><br />You cannot run it out of water AT ALL, or the rubber waterpump impeller will get porked. There is a hose attachment you can buy for cheap to let you put water to it when it's out of water.<br /><br />If it's new to you with an unknown or spotty history you should:<br /><br />Get a service manual ($25)<br />Do a compression test<br />Put in a new waterpump impeller ($24)<br />Change the lower unit lube ($6-$8)<br />Make sure the max advance is 21 degrees not more<br />Put a kit in the fuel pump (under $20)<br />Clean the carbs<br />Then once it's running do the timing and sync procedure in full.<br /><br />Even if it came to you for free - there's no such thing as a free outboard. Spending a weekend and doing *all* of the above will save you many hundreds in repairs later. If you can't do all this yourself, take it to a Mercury shop where you get a "vibe" that they are both competant and enthusiastic to work on the old inlines.<br /><br />-W
johnlj68
thanks, where do you hook up this hose so you can run it on land? thanks, John
Clams Canino
See my edited post above too.<br /><br />the thing you get for the hose looks like a pair of earmuffs. They go over the water intake holes on the lower unit directly above the "bullet" part. You need to cover all the holes completely with the muffs. Also do not run it over 2000 rpm's out of the water with no load - it hurts them.<br /><br />Oh! and welcome to Iboats - a cool place.<br /><br />-W
Clams Canino
I think you can order one right on the iBoats website. If not just go into your FLMD (Friendly Local Merc Dealer) with the serial number and order the Mercury service manual. The lower unit is covered in that manual.<br /><br />-W
johnlj68
Also where can i get a manual for this motor and the lower unit? thanks, John
johnlj68
Thanks, clams. This is a cool place. This boat does run, but i think i will do everything you suggested in the forum, if i can find the items. Thanks Again, John
Clams Canino
Clymer manual B726 covers 1972-1989. You didn't mention the HP of your inline?<br /><br />-W
johnlj68
Sorry, Its a 115 h.p Where is that water impellar shaft? The person i bought it from said he had it running, dead now, so dont know if it was in water or not. Thanks, John
Clams Canino
OK, the manual I listed definately covers it. <br />The waterpump impeller is in the lower unit. It rides on top of the driveshaft, it is a little pump with a rubber vaned impeller.<br /><br />-W
johnlj68
ok, thanks,Now i will try and see what ican do with all this information Thanks, John
Clams Canino
You're welcome... ALSO, run only mid-grade gas in it.<br /><br />-W
johnlj68
Ok clams, thanks. Can i get the muffs at any boating marina or is there someplace special i have to get them? Thanks, JJ
