I have twin 2003 150 mercurys and both of them are very cold natured. I replaced the spark plugs (@$10 a piece!!!!!)and it helped the problem a lot but them I began to start thinking about my starting technique. I have always owned carburated outboards, 6 different ones in the last 10 years all different makes and models. I have always used the same starting technique. I adjust the throttle to the fast ideal position. turn the key to the run position, push in on the choke, turn the key to the start position, starter engages. I will let the starter turn for 5-10 seconds and then stop. repeat the above procedure till the engine "hits" or fires. Once it does, I will then turn the key to the start position without pressing the choke. The motor will usually fire right away and I will adjust the throttle to keep the RPM below 2000 and press the choke in till the engine gets warm enough to run by itself, usually about 5-6 seconds, I then release the choke and slowly return the throttle to the neutral position. I have use this technique with all my 2 stroke outboards. I talked to an older gentleman a little while back and he said to "push the key in 3-4 times before starting because it squirts gas into the carbs". then release the key and just turn the engine to the start position. So basically what I am getting at here is what is the proper starting technique for a carburated 2003 150 Mercury outboard? Any help would be appricated so I can take proper care of my Mercury investment. Thanks.
