Did I screw up?
Big T Bassman
Just did a compression on a 1996 150 EFI. I removed all the plugs and did a quick check. I did not ground the wires which I now see is the proper way for an outboard. In reviewing past posts some advise, doing this or you could burn up a control box. Please tell me I'm ok. Thanks
cfcstl
Re: Did I screw up?
I too would like to know how to ground the plugs or wires when checking compression. <br />Just curious what techniques people use to ensure grounding of plugs or wires.
rodbolt
Re: Did I screw up?
well if I am not checking spark and just compression I jut pull the stop lanyard. this does not work on 95 up johnnyrude but works on mercs. if not then open the wallet and buy an s-48 or equivalent spark tester
achris
More fish than mountain goat
Re: Did I screw up?
Never bothered grounding or disabling the spark. Just make sure I didn't touch the wires while checking the compression. Never blown a pack.<br /><br />Chris.......
KCLOST
Re: Did I screw up?
I have rigged up a cheap series of leads that run from each plug boot to a common ground... It looks crazy but it works.... I remove every plug lead when doing a test and just pull the plug that goes to the cylinder I'm measuring. Repeat as necessary.. I've always done it this way so the engine wouldn't fire up...<br /><br />But that stop lanyard thing is a great idea!!!! :eek:
