Are these the right parts for my motor?
benpung
ok, i have an old merc outboard, 110 9.8hp. SN3267352. from what i've seen, this is a 1972. it starts hard and doesn't idle well and i can tell the carb gaskets are old and seeping fuel so i want to do a carb rebuild on it. i was looking online to order some parts. can someone please look at the links below and tell me if these are the right parts for this motor? i ask b/c i looked on the carb and it has more than one number stamped on the top of it. the numbers are 1399-1930, 1399-4664. these numbers don't match the part numbers in the link, but they look right from the pictures in my seloc manual. any pointers? i really appreciate the help.<br /><br />bp<br /><br />fuel pump rebuild kit:<br /> http://www.oldmercs.com/fuelsys.html#fpkit <br />part #: 21-30430A2<br /><br />carb rebuild kit:<br /> http://www.oldmercs.com/fuelsys.html#ck81 <br />part #: 1395-9258A1<br /><br />carb float:<br /> http://www.oldmercs.com/fuelsys.html#floats <br />part #: 1395-8673<br /><br />filter screen part number: 1399-3938 (same page as above links)
NathanY
Re: Are these the right parts for my motor?
1395-8763, that is the correct float.<br />1399-1717 is the GASKET AND PACKING SET<br />21-30430A2 is the correct fuel pump kit.<br /><br />1399-4206 Repair kit is NLA
NathanY
1395-9258A1 is not a Mercury part # according to Mercury.
benpung
so i got the right float and fuel pump kit, that is good. i have a couple follow up questions:<br /><br />1. as for the carb, are you positive that 1399-1717 is the right part #? why is my carb stamped with those other numbers? is it possible i have the wrong carb, or don't those numbers i'm reading off the top mean anything?<br /><br />2. could the carb kit in the link above be the right kit w/ the wrong number on it?<br /><br />3. do i need the filter screen for this or not? <br /><br />4. can you reccommend a source where i can purchase these parts? <br /><br />5. what does "1399-4206 Repair kit is NLA" mean? i'm not sure what NLA is and what is all included in this repair kit?<br /><br />as always, thanks a lot for the help.<br />bp
benpung
also, if 1399-1717 is the right carb gasket and packing kit, can you give the the part numbers for the needles and seats and so on that i will need? thx.<br /><br />bp
NathanY
NLA means No Longer Available, as in your needles and seats. They just offer a seal and gasket kit. I get mine from www.mercruiserparts.com You can look up your motor by serial number. They will have picture and diagrams for looking up parts.
benpung
great. thanks for the help.
