Merc 65 ignition switch problem.
steviecops
Hi<br />I just got a blueband Mercury 65 hp to play with! I'll post the serial number tomorrow, but it's the one with the plastic, square shaped cowling.<br /><br />The previous owner says that it was a good runner, but the ignition switch failed and he replaced it with an automotive switch! I know that's a bad move, and he did burn some wiring inside the control box. <br /><br />What I need to know is, could he have damaged any of the electrical parts under the cowling, ie, coils, rectifier, etc? I've had a quick look, and all the wiring under there looks O.K and I can't see anything that is obviously burned.<br /><br />Thanks<br />Steve
Laddies
Banned
Re: Merc 65 ignition switch problem.
With a battery ign on switch he has at lest burned up the switch box by hitting the Ground off termenal wiht 12 volts. (Inless he isn the luckest guy around)
steviecops
Where is the switch box? Is it the actual key switch inside the control box, or is it one of the electric components under the hood?<br /><br />Thanks<br />Steve
Laddies
Banned
It is the Ign. Box that is on the side of the motor the wires from the coils and the wires from the stator under the flywheel attach to it, Itis heart of the system and tells the ign. when to fire.
steviecops
Oh I see, it's the powerpack. I was afraid of that, it'll be an expensive repair. Wouldn't anything else blow before the powerpack? I know on the OMC's that if you hook the battery up the wrong way, it'll burn out the rectifier pretty quick, but the powerpaqck usually survives. I'm not very familiar with Merc's though.<br /><br />Any further info would be appreciated.<br /><br />Thanks.<br />Steve
Laddies
Banned
That the differace between battery powered Ign.(OMC and Mercurys earliest type) and the newer style alt. drived type the earlier type ran on DC voltage and the alt. on AC voltage
steviecops
So there wouldn't be a fuse in the wiring harness or anything protecting the engines electrics?<br /><br />Thanks<br />Steve
Laddies
Banned
No they like to sell past. God I wish I could type and spell better!
steviecops
O.K, thanks.<br /><br />So assuming that the powerpack/switchbox is the most likely thing to have been damaged, is there a simple test I can do to find out if it's cooked?<br /><br />Thanks<br />Steve
