fallafalla
- Joined
- Jan 9, 2005
- 9
Hi<br />I have a merc 650 SS i think serial number 2216883. I have a couple of problems with this outboard i hope you can help with.The first problem was that no water was coming from the tell tale so my dad took the bottom leg off to check the water pump impeller and it was fine and after a while decided to put the leg back on but after reasembling the outboard it was stuck in gear and the trottle did not work and still the tell tale had nothing. Do you have any ideas on what could be wrong?<br /><br />UPDATE : The gear issuse has been fixed thank you.
