Moody Blue
- Joined
- May 24, 2004
- 3,136
1992 40HP Mariner 4 cyl. Searched the forums but havn't found any relavent info. Hoping someone can offer some assistance. <br />Problem 1)After removing the lower unit I noticed that the water pump housing is not separated/protected from the exhaust tube. Is this normal ? Parts dwgs online show some kind of rectangular shaped seal and collar as part of the lower unit that my motor doesn't seem to have. Is it missing or is this normal ? There is no sign of any damage or distortion from heat.<br />Problem 2) My Clymers manual refers to an o-ring on the drive shaft. The water pump repair kit came with an o-ring about 3/4" dia but one was not found when I removed the lower unit. There is a slight groove on the drive shaft just below the top splined section. Does an o-ring go there ?<br />Thanks for any help.
