65 mercury
- Joined
- Apr 15, 2005
- 3
i was told that it was the switch box or the trigger how can i test these? Thanks in advance
Would that also apply to a 65hp w/Thunderbolt ignition?<br />Thanks,<br />MikeOriginally posted by Laddies:<br /> 1-- disconnect the blk/yel wire at the switch box and ck for fire.<br />2--you need a DVA a OHM. meter will work but nots good, H/speed wires should read,Red to ground 20v+ or 135to165 ohms, the L/speed should read,Blue180v+ or 5800to7000 ohms.<br />3--Trigger wires 4v+ or 750to1400 ohms
I was told by the local marina that it was a 1965 according to their records, but Mercury parts said it was a 1971 serial number??????? Ser. # 3036568Originally posted by Laddies:<br /> What year or seriel number
