Moody Blue
- Joined
- May 24, 2004
- 3,136
Got the motor running first time this year, 92 Mariner 40HP 4cyl. Added a tach earlier this spring and after firing up the motor the tach was dead. Checked for signal at the tach - none. Checked for signal at the rectifier terminal that tach wire is hooked up to - none. Checked other rectifier terminal - signal. Switched tach wire to the other terminal and tach works fine. I thought each side of the rectifier would be the same ??? Output voltage is 13.8V @ idle and higher as RPM is increased so I am assuming the rectifier is OK. I am puzzled. Should a voltage not be present at either terminal ?
