Regulators: OEM or not?
nfrnkish
I suspected I'd blown my regulator using the battery switch while running - no tacho, volts at battery the same whether engine running or not. The Seloc manual has a static resistance test.<br /><br />Did the static test after a fashion - I don't have thick and thin red wires. The tach resistance was completely wrong, as was the resistance of a stator input to ground. A new one will be needed. A supplier in the US quoted me for a CDI regulator with a different part No. (also more expensive at $120 + $9 P&P). Is it a direct replacement? I await his reply.<br /><br />Still never found the Mercury part No.<br /><br />1995 115 Hp 4 cyl Mercury OG198241
Laddies
Banned
Re: Regulators: OEM or not?
CDI is a division of Rapair their electronic parts are light years ahead of Mercury Marines--Bob :eek: god I hate to say that
Laddies
Banned
Try mercuiserparts.com this is a dealer site but has a much better parts section, if I understand right the number you need was original 884515 and was changed to 883072 ck it out on this site--Bob
nfrnkish
Looking at Mercury parts express pages (again and again!), there appears to be an item on the diagram (ref#10) which looks like the regulator, but there is no part No., or name, only N/A. do they not supply the part anymore?
nfrnkish
Maybe I got the wrong site - mercruiserparts.com seemed to be just a links page
nfrnkish
Got the site, but both of those part No.s cannot be found, and trying to find by picture, it just gives a rectifier, not the rectifier/regulator that I think I need...
Laddies
Banned
Sorry I just tryed it and got the same thing, go to BAM marine and item 3 is mercrusierparts so go that way, then these instrutions should work -Did you click online ordering for mercury-mercruisier,then go to search with pictures, then to merc mariner force outboards, then go to mercury marinier outboards, then it will list models a seriel numbers and then alast you can ck part numbers
Laddies
Banned
Same motor look in the other seriel number group in the electrical section
north40
Go to ishopmarine.com. Part number 883072T ....about $110.00
pegleg319
nfrnkish.<br /> I just checked www.mercruiserparts.com. Go to online look-up, serch with pic's,product line,mercury,mariner,force & other outboards.<br /> Select catagory mercury/mariner,select model,<br />Description 115 4 (cyl) Serial Range 0D283222-0G760299 Electrical componants Part # 10 883072T superceeded by part # 815279T. This is the same part that i toasted on my 1996 60hp. Merc. I had the same problem no tach/no charging, hope this will help you.<br /> Regards Bill
north40
Ishopmarine.com also has CDI made unit for 97.05. The OEM part is 109.55.
nfrnkish
Excellent! thank you very much for all the help guys. Strange that the Mercury Parts Express page has n/a for the regulator....but ref#10 on the Mercruiser page is definately the same picture as that on the Mercury Parts Express page.<br /><br />Only one question remains: if the CDI component is better and cheaper, is it a direct fit? no "cutting and shutting" to get it on?
pegleg319
Mine fit right in,if you use the right part you should have no problems.
Laddies
Banned
CDI has great products, all are dirict fit or in cases with differant style connecters supply the adapter wires, those part numbers are followed by a K --Bob
nfrnkish
Thanks for all the help. Interestingly, ishopmarine lists another aftermarket replacement, the Sierra 18-5743. It is the most expensive at$113, but from a Canadian site (can't find manufacturers site), it is capacitor protected from voltage spikes. I doubt that this means you can disconnect the battery while running! However, on this topic, I find it hard to believe that it would be difficult to engineer circuit protection for VRs. Is this a case of ommision to stimulate the replacement market?
