In the lower unit behind the prop is a left handed "nut" that holds in the seal and bearing retainer, mine came loose. What if anything keep this tight. Thanks!
Thats not a common problem with a carrier nut they ussally come out from freezeing ck the threads if thet are OK then coat the nut with perfect seal or something like it and reinsall the nut with a spanner
