bmcraddock
Thread starter- Joined
- May 11, 2005
- 4
Hello,<br /><br />I've got a 2 Stroke Mariner 60 approx. 1995 with problems...<br /><br />The engine was running at all speeds absolutely fine for about 45 mins, then at about 3/4 speed the revs suddenly dropped and then the engine cut out. After it cut out there was a slick of fuel on the water around the engine.<br /><br />The engine re-starts fairly easily and will run at low speeds ok, occasionally cutting out on tick over, but as soon as its opened up the revs will drop and stall, leaving a slick of fuel in the water.<br /><br />The engine has recently been serviced and allegedly the carb has been cleaned and tuned.<br /><br />Any thoughts, suggestions, wisdom would be much appreciated as I can't really afford more huge repair bills...<br /><br />Thanks - Ben
