removing thermostat on 95 225 carb
ricksmith
I was looking at a 225 on ebay and the stated he had removed the thermostats due to overheating. Since the thermostats open at a relative low temp..(140 I think) would this be a problem?
KCLOST
Re: removing thermostat on 95 225 carb
Yep,<br /><br />You don't want to run that motor without the stats... They are designed to regulate the water flow through the heads and ensure proper cooling capabilities in relation to the temp.
Coolmaker
You can remove the stats, but you must install a washer with a 3/16 hole in it to regulate the water flow. It will also burn more gas with the stats out. good luck...
KCLOST
Not a good way to solve an overheat problem.... And not as the motor was designed....
