thanks laddies, so if I wanted to hook gauges up so that they will start when the key is turned 'on', i would wire them into the white wire? is that right?<br /><br />cheers
thankyou for your help. That's connector has three slits in it. Which one do I use, and if i connect to here and dasey chain the gauges of the tach, they should all work when the switch in 'on'.<br />Is that right?<br /><br />Cheers
