Motor runs good but prop hardly turns.
Bearcamp
1980 mercury 7.5 runs great at idle and at full throttle. But the prop hardly turns. It's like the motor is runnin full throttle and the speed is like trolling. I have this also in another post. But what is the rod that comes up from the lower unit with a metal ball on the end. Does the ball part connect to anything?
Laddies
Banned
Re: Motor runs good but prop hardly turns.
Thats the tilt lock rod your looking at it should go into the lock dog assm. ck your prop hub for slippage--Bob
Bearcamp
How do I check the prop hub? And what would I replace if it's bad, the prop?
Ben Konopacky
mark your prop near the nut in three places in a row,1 on the prop housing,2 on the rubber bushing, and 3 on the splined bushing, run the eng.and then check if any of the 3 marks are out of alignment.If not aligned you have a " SPUN PROP ",needs to be re hubbed..
Bearcamp
But is it possible to che4ck it by trying to turn it by hand? I don't know.
Ben Konopacky
it's possable,if it's real bad,how are you going to torque it to meas.when it starts to give way?? take it to a prop shop,let them check it out this way you era sure..
Bearcamp
Well around my way we don't have a prop shop. If I discover it's bad I have to remove it to replace. I already remove the nut and washer, but the prop won't move. Is there a special way to remove it? Can I do it without any special puller? I did spray it with Deep Creep oil.
