Bad Poppet valve on 2001 135 Optimax?
zarnold
My 2001 135 Optimax had starting problems the other day, like it was very cold. Once it started it ran very rough for a couple of minutes, but then seemed to be OK. Later that day the heat alarm went off. Not knowing the exact maintenance history of the motor I replaced the water pump, but the heat alarm is still going off. The alarm does not trigger at idle, but at about 1000 RPM’s, if I bring it back to idle the alarm shuts down. The shop manual indicates that a hard start, rough idle, and the heat alarm may be the result of a bad Poppet valve. Does the make since, or should I look for a different cause of the heat alarm.
KCLOST
Re: Bad Poppet valve on 2001 135 Optimax?
Could be it, very easy to check also..
zarnold
Turns out that my starboard side temperature sensor was bad, changed it and the thermostat, and I’m back in business.
