50 hp merc lost two clyinders
jefa
1986 merc 50 wont go past 2200 rpm, rebuilt carbs and cleaned fuel system, no change, checked for spark today, two cylinders dead. Can the coils be tested? or should I swap dead for live and see if problem moves?
jefa
Re: 50 hp merc lost two clyinders
counting from the top. 1 and 2
fishingdan
You have got my attention. I am having a similar problem, but mine started after I fixed a leaky carb. I don't think I have dropped any cylinders, but I need to check that out. <br /><br />Just curious, how does yours idle? Can you tell that it is running on 2 of 4 when it is idling? <br /><br />I had a rough idle, but top end was fine when I found the leak. I took the carb off, repaired the leak, reinstalled the carb and now it has no power on the high-end. <br /><br />I posted a new topic for my problem earlier. I will be watching this thread.<br /><br />Thanks
jefa
idle is ok and revs all the way up in neutral
fishingdan
hmmm...this is sounding familiar. I guess I will be checking for spark tomorrow. <br /><br />Thanks
Laddies
Banned
The engine will free rev on 2 cyls, with no spark on 1 and it'e either the stator or switch box, to tell which it is with no DVA, change the Red and red/white and the blue/ blue white wires on the switch box, if the spark changes from 1+2 to 3+4 you have a bad stator, if it stays the same you have a bad switch box -- Bob
jefa
Thanks Bob , will try today and report back. Jefa
