Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
Get the manual and ohm out the stator, then the trigger, then the switchboxes get suspected. Disconeect the blk/wht bias wire between the 2 boxes to isolate them for tests.<br /><br />-W
First, Nightstalker, go to the Engine FAQs section, "Outboard wont start".<br /><br />Report what you find. It is likely that Clams has you on the right track, but I would like to know that you don't have a fuel problem.
Checked it out Sat. No spark but it's getting fuel. Switchplate OK, rectifier OK, some other little guez OK. We gave up and called the local Merc. dealer. He's supposed to look at it this week.<br />Stalker
Guy from marina comes, checks engine, says it's the starting switch. Puts new switch in and she fires right up. He started engine from beneath the shroud first (I couldn't see what he hooked up). I guess the starting switch not only controls the starter but also the spark to the plugs. I would have never thought of checking that out (I didn't see anything in the shop manual about checking the starter switch). Cost my buddy $200 for the switch and two hours of "road" labor.><br />Stalker
