1966 110 9.8hp PROP
dajohnson53
Re: 1966 110 9.8hp PROP
The prop finder here at IBoats probably won't show one for your engine, nor will many prop sites. You can probably get one through a local dealer if you have one. That's what I did and later when I discovered online sources (mercruiserparts.com), I found the price about the same locally.
yrsouth
whats the name of your local boat dealer? still have yet to find any prop anywhere to include michigan wheel.
dajohnson53
As I mentioned, you will not find this prop in the prop websites. Look for it on websites that have mercury parts. Have you tried calling your local merc dealer? Do that first, or go to this site<br /> mercury parts look up <br /><br />Look for parts for your engine's serial number. Look at the gear housing area. You will see the part number for the original propeller is probably no longer available, but if you look further, you will find a current part number for a propeller for that engine. You could either order from the online source or give that part number to your local merc. dealer. Hope this helps.
