Re: burned up # 3
Deagle do you have a manual for the motor ? Sounds like you don't. Take a deep breath, grab a cold beer and sit back for a few minutes and gather your thoughts. You need to approach any problem like this in a methodical manner. It will get resolved faster than if you bounce from one issue to another.<br /><br />Answer the members questions as clearly as possible and resolve one issue before heading off onto another. <br /><br />
they hit the bolts when they turn
Do you have more than one of what you are talking about ?<br /><br />
these impellers seem to big because they hit the bolts when they turn
What about these bolts? Still not resolved, is it ?<br /><br />
1966 merc 65 hp 3cylinders
Its been stated that Merc did not make a 3 cyl of that year. Are you certain you have the right parts then ? What is the S/N of the motor. Perhaps someone on this forum can determine the year and model for you.<br /><br />
do i need a compression check?
Where did this come from ? Weren't you trying to resolve the waterpump issue ?<br /><br />
but when the lower unit is back on there is still no water
Why did you put it back together if you think you might have the wrong parts or if something was not fitting properly ? Was the engine running or just muffs installed ?
