beaverhound
- Joined
- Jun 9, 2005
- 1
I have a 1997 25hp merc tiller. It sat for 3 yrs. i replaced plugs, waterpump, fuel pump diaphram, and completely disasembled the carb and cleaned. i put it all back together and tried to start. i primed the fuel filter and pulled til i was blue. the prime on the carb wont even squirt any fuel. so then i shot a squirt of ether in the carb and opened the throttle manually and gave a pull. fired right up but the minute you let it below say 2000 rpms it stalls. the pump isnt pumping so i even checked the vaccum lines and the plate the carb mounts to for restriction but theyre all clear. i wish i could bypass the pump but on this model the pump is cast to the side of the carb. any suggestions?
