IL6 1150 Carb Question
stant1man
Hi folks, i have completely rebuilt my carbs and have enjoyed doing so. It was really much easier than I expected. Thing is, when I squeeze the primer bulb, fuel comes out of the carbs.<br /><br />Should this happen?<br /><br />Thanks<br /><br /><br />Stan
Laddies
Banned
Re: IL6 1150 Carb Question
No, the inlet needles are leaking and that should not be happening
stant1man
Thanks Laddies,<br /><br />I have replaced the needles, seats and floats. The primer bulb does go hard. It only happens if I apply extra pressure after it stiffens up.<br /><br />What should I do now?
boatdoc
with enough pressure u can override the needle and seats which is probably whats happening
ColdFire
It's normal if you apply enough pressure. Sometimes with these cold blooded beast it is what it takes to get them started :)
stant1man
A few people have said the same guys, thanks for the help.<br /><br />Stan
emckelvy
Actually, that's a design feature, the Advanced Mercury Inline 6 Cold-Start Priming Function!!! Most old Inlines won't start without having fuel blown past the needles and spilling into the carbs.<br /><br />As long as fuel doesn't spill out of the carbs when you pump the bulb up normally, and doesn't run out of the carbs with the motor operating, you're probably OK.<br /><br />The last of the inlines did have a 'real' priming system that worked quite well. This or any other suitable solenoid-operated priming valve could be adapted to an older Inline. <br /><br />Then the old shutter-type choke mechanism could be removed. Giving better starts and less restriction at the carbs. <br /><br />Just a thought!...........ed
2cycle
Originally posted by Ed Mc.:<br />[QB] Actually, that's a design feature, the Advanced Mercury Inline 6 Cold-Start Priming Function!!! Most old Inlines won't start without having fuel blown past the needles and spilling into the carbs.<br /><br /><br />Amen to that! It's unfortunate that most new owners (myself included at one point) aren't made fully aware of this "design feature." I wonder how many starters and batteries have been toasted trying to get one to start with only average fuel ine pressure? 5 or 6 hard squeezes once hard will allow my mid 70s 1500 to start in 5-10 seconds every time now.
