Re: installing tachometer
The original tach for that engine got it's signal from the switch box so the first thing you have to do is remove the brown wire from the 4 post side of the box and move it to the rectifier install it under either yellow wire, the new tachs pick up the signal from the alternater, then you will need a pigtail to plug in the front of the control box and any modern marine tach will hook up to it--Bob
