'97 200 EFI charging/oil problems
sangerwaker
Last fall, I had a dead battery on my last trip out for the season. I didn't do anything to it other than charge the battery. After storing the boat for a long winter nap, I recharged the battery and had it tested. It was fine, so I reinstalled it in the boat and had no problems...for a while. After about 8 trips out with the boat, the battery was dead again. I broke out the manual and did some testing on the charging system, and discovered that the upper voltage regulator/rectifier was out of spec, and thought it was bad until I read that the tach would act erractic if it was bad. My tach had worked perfectly...until Wednsday night. I have a tournament Saturday, so I charged the battery and tried to go out last night again, but after the motor ran for a couple of minutes, the oil alarm (fast beep) sounded and the motor shut down and would not restart. The alarm would sound after cranking as well. I checked my manual today and noticed that the alarm circuit for the oil has a feed from the tach circuit. I'm wondering if these two problems aren't related somehow.<br /><br />Is it possible for a bad voltage regulator/rectifier to cause these symptoms? I really hate to start throwing parts at it, especially since the rectifier is over $100.<br /><br />Sorry for the long post, but I wanted to give as many details as I could. Any help would be appreciated.
Re: '97 200 EFI charging/oil problems
Got nothing for ya, but was intrigued my the handle sangerwaker. I know what a wake is but what is a sanger? We have a Sanger not to far from here. Applying the small world syndrome forces me to ask if you have followed CATranspants example, or perhaps preceeded him.....
sangerwaker
Sanger is a brand of tournament ski boat (like Malibu or Mastercraft). My favorite barefoot tournament event is wake crossings, or waking, making me a sangerwaker.<br /><br />Anybody with any ideas on my motor issues?
Sounds to me like you may have a deeper problem. There should be a common bench test to ascertain whether or not the voltage rectifier is "good". You need to treat disease not the symptom. I have little experience with the specific circuitry but certain basics always apply.
