FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Should you use the sea foam right after rebuilding the carbs/replacining all fuel lines or after you have run the motor for a while?<br />And can a slight difference in replacement fuel line size make a difference in how it runs?
That will work good - the limit in the fuel line is the connections - where you put the hose onto the metal or plastic conjunctions. But it is generally not a good idea to downsize.<br /><br />-M-
NO, should not make any difference. If you put anything other than OEM, keep a close watch on it as they sometimes create problems because the check valve do not work properly.
