donspaulding
Thread starter- Joined
- Jun 23, 2005
- 11
Hello all!<br /><br />This is my first post and believe me, I wouldn't be posting if I hadn't spent three hours searching google and iboats for an answer.<br /><br />A little history:<br />I have a 1979 16' Mark Twain V-hull with a 1976 Merc 850 Outboard. This boat was run hard for 3 years and then sat for 2 years before I got to it this spring. I put new gas in it with a fuel additive. I put new plugs in and tested compression on the top three cylinders (all showed about 112) since my tester wouldn't fit in the lower one because of the lower cowling. I also drained the gearcase oil out of the lower unit (the oil was black but didn't show any signs of water or metal shavings).<br /><br />My problems:<br />The motor starts easily. It will slow/regular/fast idle all day long both on the muffs and in the water. It used to not drop into gear in reverse, but after adjusting the shift cable at the engine, I got it to drop into reverse without losing forward or neutral. All shifting/throttling works on the muffs, but it won't go in reverse in the lake, and won't throttle up past a fast idle in forward. Any ideas why it would behave so differently under a load?<br /><br />Any help is appreciated. I can provide pictures if they would help.
