Re: Adjusting oil injector
hate to throw gas on the fire ,,but the "alignment marks " are not that great ..good place to start ..<br />my ole 87 150 has been running a lot of year's with the alignment marks about 1/8 of a inch on the lean side ..no smoke ,no blow-ups ..<br />IF you will run pre-mix ,and this is important ,<br />TAKE THE TIME to "cc your pump " and fuel flow " then you can safely adjust it to run a cleaner mixture than the "stamped marks "<br />We usta do that to the early motorcycles that first started the "oil injection pumps'..<br />back then you used "washers to control the pump stroke ..<br />bottom line ..if you are smoking a lot during the entire rpm range ..<br />maybe ,just maybe it's time to actually see what the pump is doing ..<br />not depend on some fit -all manual..<br />what you might check tho is the "pressure relief valve in the oil feed line ..if it doesnt let pressure off ..then the crankcase pressure might "help your oil pump to a degree of "smoking <br />just my opinion .<br /><br />by the way, thanks for your service in Nam
