79 Silverline
Thread starter- Joined
- Jul 11, 2005
- 32
Hello everybody, first post here at iBoats - awesome forum.<br /><br />Here's what I got - I'm running a 90HP Inline 6 of 78' or 79' vintage (Cowling decals and timing sticker look like/say 79', but some things don't appear to match up). Ever since I started her up this summer, she idles rough and will go out if left idling long enough. However, when you got on the power, she'd open up and fly.<br /><br />The problem happened when I was flying across the lake and hit a wake hard a couple times and the engine bogged severely. She will NOT go past about 1/4th of 1/3rd throttle. Sounds like needles and seats or jammed carbs right? Nope. I had just rebuilt all 3 carbs (floats, needles, seats, kits), and then field stripped, inspected and cleaned them two times that day to no avail. Fuel pump? I rebuilt it before the trip, and stripped and inspected it. It's fine too. Pumping the primer bulb shows that the carbs are full.<br /><br />Inspecting all 6 plugs, they look a little fouled from extra fuel/oil but that's no surprise. Didn't do any chops, obviously. Flashlight shows that I have all 6 pistons left and the cylinder walls are still present and accounted for. Before I left, all 6 had 150-155 PSI compression.<br /><br />I have a brand new CDI ignition switchbox and coil combo, and it obviously fires the engine up, it's just not keeping the fire lit at higher speed, and idle is choppy. Checked my connections already. Once I was home, a timing light shows missing ignition events that seem to coincide with the engine stuttering - it gets reaaaly bad when I try to mash the throttle. So it's spark.<br /><br />I'll try to round this off here as it's getting long winded - but could this problem be from a dying, but not yet fully dead trigger? I have no experience with outboards, and don't know how to test one of these things, or even remove it. Can a trigger start getting intermittent? I'd appreciate ANY information you guys could share, as I'm really not sure what the deal is or how to proceed. Thanks!
