tengals123
Thread starter- Joined
- Jan 26, 2005
- 860
GUYS PLEASE HELP ME OUT ON THIS ONE. I can't get into reverse. I have tried re installing the LU in every position. F N R<br /><br />If I reinstall in reverse, all is fine. Then up to neutral fine. Then continue to forward I get a Audioble 'click' and goes into forward. Now back to neutral fine. When I move back to reverse it stays in neutral. I end up only with forward and neutral. The same thing happens any way I reinstall the LU. <br />Things to note.<br />1. With the LU removes and shifting from full foward to full reverse via the forward controls, and looking up the skeg the shifter only moves a tiny bit. Like a few millimeters each way? Is this right?<br />2. The shifter on the LU when moved has like a tiny movement for reverse, turn it a little more and into neutral ( tiny movement ) then turn it more and into forward, now in forward the shifter will move about 2/3 of a full rotation until it finds resistance to go back to the reverse position. So it's like 1/3 of rotation is for N and R and 2/3 for F. Is this right. I just cant seem to get this right. PLEASE HELP.<br />Thanks in advance<br />cheers
