1995 15 hp merc water pump
hot57chev
Ok help<br />trying to replace water pump, can not get lower leg to drop more than an inch.It is in forward, drive shaft is out of crank as fly stops turning while turning prop.<br />My problem is with shift linkage? do I undo it up in the top end?<br />Iam I missing some thing <br />Thanks<br />Jeff
wilde1j
Re: 1995 15 hp merc water pump
Do you have a shop manual? If not, I would suggest getting an OEM manual. Makes all maint. much easier.
hot57chev
This is a one time job for a female friend<br />Hope to never see this kicker again lol.<br />Don’t really want to buy a manual; I was hoping to get all the needed help from you merc specialists
hot57chev
Thanks for the address Jim<br />Solves all my questions.<br />Like I said, this is a one time job for a friend and a manual is not in her budget.<br /><br />so your comment about (a BTW, this board is not a substitute for a shop manual.) really isn’t necessary.<br />Sorry to bother you with simple water pump question<br />Not everyone has a mind boggling problem for you to solve.
