Re: primer bulb firms up, then collapses, what's up?
vampirefish <br />Member # 53457 posted July 20, 2005 12:52 PM<br />--------------------------------------------------------------------------------<br /> Hey Vlad D Impeller, you mentioned "Fuel tank not properly venting, or an air leak in the fuel lines"<br /><br />I have a question: Should the fuel tank be vented or not at all? Mine has a little vent on the top of the fuel cap. I've been tightening this down and my engine runs fine out of the water, but when it's in the water I am not getting enough fuel.. could this cause this type of problem? Either way...should this be vented slightly, not at all..etc..? <br />_________________________________________________________<br /><br /><br />The fuel tank must be allowed to vent, meaning that air gets to replace the displaced fuel.<br />If you close of the vent, you will encounter fuel starvation.
