vampirefish
- Joined
- Feb 14, 2005
- 195
Ok....so the saga continues
Sorry for the long post. Took my boat out on the water last night for it's 1st 'trial run'...<br /><br />It took a while to start the engine and warm it up. Here's the problem... Once I got it to idle it would only idle (nuetral) with the throttle midway (sorry, no tach, no guages for reference) -- When I would push it all the way up, it would rev a little, but not what I would imagine (like it does out of the water). And forget trying to get it to idle with any less fuel than midway - it just died.<br /><br />I was 'finally' able to get it to not die when I put it in forward, but when pushing the throttle up, it would barely go...like it's being deprived of fuel. I was only able to get it in forward (without dieing) once.<br /><br />Here's what I do know:<br />1) It runs great out of water. When I push the throttle all the way (briefly), it revs up. After it's warmed up, it idles 'almost' at the lowest throttle position. It seems to idle fine.<br />2) Compression tests were all GOOD.<br />3) In the top carb (3 total), when I first got the engine running out of the water, fuel was spirting out. I knew the float was stuck. A mechanic told me that I could try to run it out of gas...that actually worked - no more fuel spitting out when it's running.<br />4) When I tilted the engine up last night, prepping to drive off, fuel was dripping from the carbs (not a lot, but enough to notice)... not good...<br />5) I realized this morning (whilst reading this forum) that I should have had the vent opened at least a little on my fuel tank..I had it shut tight.<br /><br />Solution(s):<br />1) So due to the float being stuck on the top carb (initally) and them dripping while the engine is tilted up... I'm sure I know the answer...have to rebuild my carbs, right? If I take it into a mechanic, should they test the fuel pump as well as all other areas that fuel is running..?<br /><br />2) Could it be as simple as the fuel tank not being vented to have caused it to run like that? Of course...I'm hoping this is the solution!
