hunter0304
Thread starter- Joined
- Jul 25, 2005
- 2
Folks,<br /><br />I'm looking for some advise before I spend $200 for a new warning module (black box).<br /><br />I have a continous alarm when igintion is turned on.<br /><br />I've check the wiring to the alarm horn - no grounds or shorts. Heat sensor is open - the horn continues with the heat sensor to the head disconnected. Horn goes on and off when continous voltage is applied and the ground is interupted.<br />That means horn itself is ok?<br /><br />I assume that since the alarm is continous and continues without the sensor connected it must be in the black box?<br /><br />thanks
