70 hp mercury need to find year and manuil to wire motor an boat ?
froggy prince
I recived a boat from my dad i have a 16 ft american starcraft with 70 hp mercury motor it needs to be wired and throttle asembeld any suggestions on were i can go for manuils an scematics
Barnacle_Bill
Re: 70 hp mercury need to find year and manuil to wire motor an boat ?
Need a model number to determie year.
froggy prince
can u give me an idea where to find the modle number not on the inside cover
froggy prince
is anyone out there that can help me look for the model number..
AMD Rules
Typically the serial number is on the transom bracket, below the powerhead on the right side, when looking from rear (prop) side.<br /><br />Depending on the motor's age, it may be in the top of the transom bracket near the front of the cowling. You'd likely have seen that one.<br /><br />Failing that, check for a serial number stamped into a welch plug (size of a 25¢ coin) on the side of the block. Serial numbers are 6 or 7 digits and a prefix letter in most instances.
froggy prince
its me agian need help been looking for bracket with model number can only find serial number on motor the comp name is kiekhaefer corp can any one tell me a rough age of my motor based on manifacture ?<br />and thanx to amd rules.. i found serial number finally
andy6374
Try www.maxrules.com . He lists the serial numbers for all years and horsepower mercs/mariners.
AMD Rules
We can probably tell you the exact year , based on the serial number you found. Kiekhaefer IS Mercury. He was the founder, and for many years the brand was his name.<br /><br />What is the serial number you found?
froggy prince
the serial number is 1532575
AMD Rules
Sounds like you might have yourself a classic Mercury there!<br /><br />Does it look like this?<br /><br />1962 Model Merc 700
froggy prince
yup that is the motor we got!!!
froggy prince
ok we know that is the motor we got but we are still confused on where to get any numbers.. or get any books for it to fix it back up
gwmark78
Did you scroll down?...It's all there on amd's last post.
