tachometer options??
rustyzeus
need to install tachometer for my '73 I6 115hp Merc. Any original merc plug and play models still available or aftermarket availability. What are my options?
Laddies
Banned
Re: tachometer options??
Both Merc and aftermarket are available you will need to ck your engine and see that the sender wire is hooked to a yellow wire on the rectifier termanal and if it is not move it from the switch box to the rectifier if it's already there it is a gray wire and if you need to move it from the switch box is a brown wire on the 4 post side of the box, once the wiring is right almost any new style tach will work
rustyzeus
1. if I have a an original shift control box that has the plug on the front can I just use and orginal merc tach and plug it in. Can I assume the wiring is ready to go.<br /><br />2. The wiring instructions you have above, is that just for using and aftermarket tach?<br /><br />Sorry, I'm not sure I follow those wiring instructions. Please excuse my lack of understanding.
Laddies
Banned
Once the tach sender wire is in the right place you may use a original factory plug in at the front of the box and Mercury or aftermarket tach as all modern tachs are alternator driven, your engine is 12 post, 6 pulse there is a adjustment on the back of each tach
